CADO-NFS
Crible Algébrique: Distribution, Optimisation - Number Field Sieve
Introduction
CADO-NFS is a complete implementation in C/C++ of the Number Field Sieve (NFS) algorithm for factoring integers and computing discrete logarithms in finite fields. It consists in various programs corresponding to all the phases of the algorithm, and a general script that runs them, possibly in parallel over a network of computers. CADO-NFS is distributed under the Gnu Lesser General Public License (LGPL) version 2.1 (or any later version).
CADO-NFS is the result of a collaborative effort involving many persons, over various periods of time. The current list of active contributors can be extracted from the git repository or from the openhub.net page. A tentative list of CADO-NFS authors is (alphabetical order):
Citing CADO-NFS
The recommended way to cite CADO-NFS in a scientific publication is (bibtex entry):
where the release number and date should be changed to correspond to the version you actually used. If you used the development version, it is a good idea to give the git revision number. You can, at the very least, say "development version" and give the current date. You can base your citation entry on the following template (bibtex entry for the development version, to be completed):
Features
Algorithms used in CADO-NFS 2.3.0 are the following:
Speed comparison of CADO-NFS versions 1.1 and 2.0, obtained on a dual 8-core Intel(R) Xeon(R) CPU E5-2650 at 2.00GHz, running Linux 3.2.0. Both CADO releases were compiled with gcc 4.7.2.
With CADO-NFS 1.1 using cadofactor.pl, the timing runs used 16 processes of 1 thread each for polynomial selection and 8 processes of 2 threads each for sieving; with CADO-NFS 2.0 using cadofactor.py, both phases used 8 processes of two threads each, with CADO-NFS 2.1 using ./factor.sh N -s 8 -t 2 tasks.linalg.bwc.threads=16. With CADO-NFS 2.3, the same behavior is obtained with ./cado-nfs.py --client-threads 2 --server-threads 16 --slaves 8. The table below lists CPU time [wall clock time in square brackets].
Input number CADO-NFS 1.1 CADO-NFS 2.0 CADO-NFS 2.1 CADO-NFS 2.2.0 CADO-NFS 2.3.0
RSA-120 100 hours 45.6 hours 45.2 hours [3.6 hours] 32.2 hours [2.2 hours] 26 hours [1.9 hours]
RSA-130 288 hours 231 hours 219 hours [15.9 hours] 124 hours [8.2 hours] 107 hours [7.5 hours]
RSA-140 809 hours 614 hours 643 hours [45.7 hours] 469 hours [30.9 hours] 352 hours [23 hours]
RSA-155 268 days 141 days 126 days [12.2 days] 90 days [5.8 days] 83 days [5.3 days]
For 85- to 100-digits, Ben Buhrow compared various QS and NFS tools, see here.
You can browse into the development tree history to find the NEWS file for past releases:
Last modification: Fri 10 Feb 2023 04:32:57 PM UTC
© 2006– The CADO-NFS Development Team. ; valid XHTML 1.0, valid CSS
